AutoCAD Forum
Move a subtracted region
3 REPLIES 3
tq1918
1037 Views, 3 Replies
I have a cylinder “subtracted” from an extruded rectangle.  The hole moved 2” to the east.  Is there a way to add a cylinder back to the solid to re subtract the hole in a new location.
Real world: (It is a sleeve hole in concrete up through many floors, due to coordination the hole moved)
I thank you in advance, and will I’ll give kudos to any and all good answers and of course I'll select accepted solution when solved.
3 REPLIES 3
Patchy
in reply to: tq1918
tq1918
in reply to: tq1918
_SOLIDEDIT
_FACE
_MOVE
GrantsPirate
in reply to: tq1918
Hold Ctrl down and pick on the inside of the hole, a red grip appears, grab that, pull in the direction needed and type 2.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
”Boost
