I have a cylinder “subtracted” from an extruded rectangle. The hole moved 2” to the east. Is there a way to add a cylinder back to the solid to re subtract the hole in a new location.
Real world: (It is a sleeve hole in concrete up through many floors, due to coordination the hole moved)
I thank you in advance, and will I’ll give kudos to any and all good answers and of course I'll select accepted solution when solved.
Solved by GrantsPirate. Go to Solution.
Solved by tq1918. Go to Solution.
Solved by Patchy. Go to Solution.
Hold Ctrl down and pick on the inside of the hole, a red grip appears, grab that, pull in the direction needed and type 2.
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
