I have done a lot of searching through previous mouse glitch related topics/threads and have come up with no solutions for my specific problem, so here we go:
-On AutoCAD 2013 using .dwg
-Mouse jumps around, is slow, and glitches
-Happens on exisiting drawings as well as blank, new drawings
-Just started to happen 2 days ago, i have had zero issues before then
-Using a Logitech M305 mouse
-When using touch pad mouse the glitching lightens up, but is still there
-On a Dell laptop using 64-bit Windows 7, Intel(R) Core(TM) i7-2670QM CPU @ 2.20GHz with 8.00GB RAM (7.90GB useable)
PLEASE HELP!!!!!
try after setting the variable SNAPMODE to 0
or
turn-off this button in the status bar.
Did not work
I also tried everything in this thread:http://forums.autodesk.com/t5/AutoCAD-2013-2014-DWG-Format/jerky-cursor-problems-with-Win-7-64-bit/t...
And here: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15127843&linkID=9240617
try another mouse and see if it still happens
DarrenP
Something else that i have noticed is that if I move the mouse continuously for about 10-20 seconds, the glitching is reduced and eventually quits. That is until I click on something, then I have to go through the whole ordeal again until it stops. Such a pita.
The M305 is wireless -- try going with a wired mouse instead. I've head reports that usb 3 can cause problems with wireless peripherals.
Move the mouse off the Shag rug.
I was going to suggest making sure the lens is clean if a laser or optical mouse but since it is happening across multiple meece that would not seem the case.
Are you sure MS did not provide you with some new and improved software for the mouse in the last couple of days?
Might be worth a look to see if an update like that occured. I went back to a previous versions software when the newer version proved less than worthy.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
if running the logitech Setpoint, try un-installing that. if you don't have it running, try installing and see if that helps.
updated the mouse, cleaned the lens, installed Setpoint, Uninstalled Setpoint and this issue is STILL occuring
'K, here's my next guess. Somewhere in the setpoint software there's a setting to turn down the resolution of the mouse - I'm not at a machine with setpoint right now, but on my home box I eventually got around to finding that control and reducing the resolution. On that box there was a noticeable improvement - the cursor was less twitchy and it was easier to click on the point I wanted without the crowsshairs jittering around.
