When I start up my AutoCad 2013 I get the followiing message -
"Module Program Directory does not exist> May need to reinstall" What is the MPD and how does one reinstall it? The program seems to be running OK but that msg. is a bit distrubing.
The 2013 is part of the Product Design Suite Professional and is running on a Lenovo S-30/Win 7 Pro.
am I right that you run AutoCAD Mechanical?
If so you have the choice of starting AutoCAD with 2 different profiles, do you get this message in every of these 2 profiles?
If you are running plain AutoCAD and you have not done too much customization you might try to reset the AutoCAD profile (Windows start menu ==> Autodesk ==> AutoCAD 2013 ==> Reset settings to default)
- alfred -
>> Any chance I could talk you into using Team Viewer and locking on to my system?
No, does not make sense as I don't know Mechanical. So I think it's better to get in contact with people knowing it better/best from there: >>>the forum for Mechanical<<<
>> it does NOT show up in the list of Autodesk programs if I
>> go to the control panel and try to reload/fix it.
That sounds like either a defect installation or very limited user permissions. Have you asked your admin to get (for a few days for testing) local admin-right?
>> I do everything in 3D and am in the process of learning Inventor
If all is 3D, then joining Inventor will be the best decission. If you have a lot of work then get a training and start with it. Waiting for the day you "have time to learn" might be waiting forever ... and that is really the wrong decission. 😉
Good luck, - alfred -
