AutoCAD 2013/2014/2015
Active Member
Message 1 of 15 (1,419 Views)
Missing "Create View" tab under Layout Ribbon
1419 Views, 14 Replies
10-12-2012 02:52 PM
I am looking to import an Inventor file and create views of it in AutoCAD 2013, However this is what appears under my Layout ribbon.
*Expert Elite*
Alfred.NESWADBA
Message 2 of 15 (1,405 Views)
Re: Missing "Create View" tab under Layout Ribbon
10-13-2012 11:10 AM in reply to: valhalla188
what happens if you right-click into the grey area and look to the section "Show panels" ... are all on (like in the screenshot):
Or have you loaded the menu from AutoCAD 2012?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
Active Member
Message 3 of 15 (1,393 Views)
10-15-2012 06:33 AM in reply to: valhalla188
Nope, they are not there. This was a fresh install a few days ago. No migration from autocad 2012. I just installed Autocad and Inventor 2013 suite with no prior copies.  I attached a picture of my screen.
*Expert Elite*
Alfred.NESWADBA
Message 4 of 15 (1,377 Views)
10-15-2012 07:02 AM in reply to: valhalla188
I have not installed a suite, so maybe there are other menu-structures defined, I don't know that.
If you start _CUI, what's the name if the main-cui and what file (including path) is loaded?
- alfred -
Alfred NESWADBA
Active Member
Message 5 of 15 (1,374 Views)
10-15-2012 07:16 AM in reply to: Alfred.NESWADBA
Path is: C:\Users\sherman\appdata\roaming\autodesk\autocad lt 2013 - english\r18\enu\support\acadlt.cuix
*Expert Elite*
Alfred.NESWADBA
Message 6 of 15 (1,368 Views)
10-15-2012 07:23 AM in reply to: valhalla188
There is something not ok, your menu points to a menu from AutoCAD LT, not for the full AutoCAD (that is part of a suite).
- alfred -
Alfred NESWADBA
*Expert Elite*
Alfred.NESWADBA
Message 7 of 15 (1,367 Views)
10-15-2012 07:25 AM in reply to: valhalla188
oops ... and more important:
It points to anything older than 2013 as R18 is valid for 2010
- alfred -
PS: this is my path: C:\Users\alfred\appdata\roaming\autodesk\autocad 2013 - english\r19.0\enu\support\acad.cuix
Alfred NESWADBA
Active Member
Message 8 of 15 (1,349 Views)
10-15-2012 10:05 AM in reply to: Alfred.NESWADBA
So how would i update/repair my version to get it to an R19 folder?
*Expert Elite*
Alfred.NESWADBA
Message 9 of 15 (1,343 Views)
10-15-2012 10:33 AM in reply to: valhalla188
first search if you have the folder that I showed (within your user-directory instead of "alfred" in my path).
If you find then a file called ACAD.CUIX within this folder start command _MENU and load this menu-file.
- alfred -
Alfred NESWADBA
Active Member
Message 10 of 15 (1,337 Views)
10-15-2012 11:39 AM in reply to: Alfred.NESWADBA
So I went to a co-worker and took at look at his Autocad. It is also 2013, and his pathing is correct.  C:\Users\tsevern\appdata\roaming\autodesk\autocad 2013 - english\r19\enu\support\acad.cuix
And he has the same problem.
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
