My company have decided to use plain autocad as the base insteed of Civil3D. Since this been done im missing information in the properties pallet.
The information im interested is shown in attachement properties 1 (This is from Civil3d)
In the properties pallet in plain autocad this information is missing se attachment Properties 2 (From plain autocad).
Is there any way to reach this information in plain autocad.
This is in autocad 2014
Solved by Alfred.NESWADBA. Go to Solution.
The shown (extended) info is of type "Object-Data".
Object-Data (OD) is an additional option to save attributive information to geometry-elements and is used especially for GIS-functionality. So you need AutoCAD Map3D (or Civil3D that has the Map3D functions also built in) to be able to access that type of information.
With plain AutoCAD you can't see/access/modify that data.
Sorry, - alfred -
Just curious, would the Civil object enabler applied to AutoCAD enable viewing these properties?
No, it does not.
- alfred -
