AutoCAD 2013/2014/2015
Member
jameyaucoin2658
Message 1 of 4 (1,121 Views)
Migrating CUI From AutoCAD Mechanical 2013 to Standard AutoCAD 2013
1121 Views, 3 Replies
06-04-2012 05:59 AM
I have a custom profile set up in ACAD Mech 2013 and I would like to import it into ACAD 2013.  When I try to import the profile to ACAD 2013 I get an error that ACAD can't load file or assembly 'AmMgdlnterop.dll' or one of its dependencies and then the program can't continue.  What am I doing wrong?
Alfred.NESWADBA
Message 2 of 4 (1,114 Views)
Re: Migrating CUI From AutoCAD Mechanical 2013 to Standard AutoCAD 2013
06-04-2012 08:36 AM in reply to: jameyaucoin2658
I would not do that as the profile from Mech has a lot of other (more) functionality than AutoCAD has. They are not compatible in that direction.
You also can't use the commands from the CUIX from Mech within plain AutoCAD. So the question is: why do you like to transfer the profile between two different product-types?
- alfred -
Alfred NESWADBA
Member
jameyaucoin2658
Message 3 of 4 (1,113 Views)
06-04-2012 08:39 AM in reply to: Alfred.NESWADBA
I am having problems with dimensining.  When I use annotative dimensions, power dimensions take over and in paper space will often give distances in Paper Space instead of scaling them.
Alfred.NESWADBA
Message 4 of 4 (1,111 Views)
06-04-2012 08:45 AM in reply to: jameyaucoin2658
So you uninstalled Mech and installed plain AutoCAD? Then you loose a lot of other functionality also, not just dimenstions :smileywink:
If you have problems with wrong dimension-value look into the >>>forum for Mech<<< is a help for you and your problem. I can't imagine that a dimensional problem is a common problem, but search in Mech-forum and if you don't find anything ask there for getting help to that.
- alfred -
Alfred NESWADBA
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
