We are experiencing delays of up to 2 seconds waiting for the menu (menu bar) and the "shift/Ctrl right click" (osnaps) to display.
The "right click" menu displays instantly both with and without objects highlighted.
Is anyone else seeing this?
I have not seen any differences after installing SP1, but from the past I remember that sometimes disabling hardware-acceleration, then quit AutoCAD, restart it, reactivate the hw-acceleration was helpful.
Otherwise (if you have not done to much customization) a reset of the AutoCAD profile (to be found in the Windows start menu) might be worth for a trial.
- alfred -
Hi Alfred,
Thanks for the suggestions, I tried changing the hardware acceleration without success but will hold off on resetting the profiles for the time being.
We are having this issue on 7 PC's (4 AutoCAD and 3 AutoCAD LT's) << forgot to mention this on the original post.
You can avoid to do that for testing, but an option to test the situation is to login with a new user-account onto Windows and start AutoCAD then.
If it's a new user the AutoCAD profile is created newly, same like resetting it. So you can test it in that way.
HTH, - alfred -
I thought I would try the installation repair option located in the program uninstaller. This seems to have helped with the delay. I will update here if anything changes. If the problem persists, I will then just reinstall the program.
have you tried my tips from my posts?
- alfred -
No, not yet. Is the hardware acceleration an Autocad option or a video card driver option?
Thank you.
>> No, not yet.
Why not? Sorry, I don't understand why anyone asks a question when some answers/suggestions are already available (at least worth to be tried).
A forum is primary a place to search for answers ... and only if I don't find any answer that solves the question I have the additional option to ask (not first ask and let others search for you).
AutoCAD command _3DCONFIG ==> manual tune (or the toogle in the status bar, lower right of the AutoCAD application window).
- alfred -
