AutoCAD 2013/2014/2015
grimline
Message 1 of 19 (4,250 Views)
MVSETUP unknown command..YGTBKM!!!
4250 Views, 18 Replies
05-23-2012 05:51 PM
Just upgraded to 2013. MVSETUP is a UNKNOWN COMMAND????!!!.
What is happening to this PLANET?!!!
please help
Autodesk AutoCAD Map 3D 2015
Windows 7 Professional
Service Pack 1
Intel(R) Core(TM) i5-4430 CPU @ 3.00 GHz
8.00 GB RAM
*Pro
nestly
Message 2 of 19 (4,243 Views)
Re: MVSETUP unknown command..YGTBKM!!!
05-23-2012 06:29 PM in reply to: grimline
MVSETUP works in my '13
*Expert Elite*
pendean
Message 3 of 19 (4,240 Views)
05-23-2012 07:09 PM in reply to: grimline
maybe it's not in MAP3D?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
grimline
Message 4 of 19 (4,234 Views)
05-23-2012 07:48 PM in reply to: pendean
Well, then somebody has to fix it because it's there when I searched AutOcad MAP 3D Help.
Just need to have it.
Service Pack 1
8.00 GB RAM
Distinguished Mentor
skintsubby
Message 5 of 19 (4,216 Views)
05-24-2012 12:33 AM in reply to: grimline
It works fine in my MAP3D 2013
*Expert Elite*
rkmcswain
Message 6 of 19 (4,193 Views)
05-24-2012 08:06 AM in reply to: grimline
greg.battin wrote:
MVSETUP is an Express Tool
MVSETUP is not an Express Tool. It is defined in a LISP file named mvsetup.lsp and is autoloaded in the Acad2013doc.lsp file. Both are part of the core install.
To the OP - did you use the "migration tools" when you installed 2013? If so, your support file search paths are probably hosed meaning the correct support files are not loading.
grimline
Message 7 of 19 (4,128 Views)
05-28-2012 04:39 PM in reply to: rkmcswain
[To the OP - did you use the "migration tools" when you installed 2013? If so, your support file search paths are probably hosed meaning the correct support files are not loading.]
No, did not notice a option to migrate tools during install. kind of occupied so I will try to find the problem to this later and get back to post the solution if I am that lucky. Thanks to all.
Service Pack 1
8.00 GB RAM
*Pro
nestly
Message 8 of 19 (4,122 Views)
05-28-2012 05:55 PM in reply to: grimline
I just realized that some of my commands don't work in 2013 (Unknown Command)
The DEMANDLOAD variable is supposed to be 3, but mine was 1.  I have no idea why it wasn't 3, because I certainly never changed it, but all seems well now at 3.
Maybe this will help?
Distinguished Contributor
cedwards
Message 9 of 19 (3,938 Views)
08-03-2012 04:43 PM in reply to: rkmcswain
I had to load acad2013doc.lsp and mvsetup.lsp manually and then go into Options-Files and add their file folder location to the Support File Search Path.
Seems to be working good now.
New Member
LRLA
Message 10 of 19 (2,716 Views)
08-06-2012 03:33 PM in reply to: grimline
Me too...need the same help.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
