AutoCAD 2013/2014/2015
radioflyer364
Message 1 of 14 (304 Views)
Lost 3D Geometry
304 Views, 13 Replies
02-07-2013 09:07 AM
I am having trouble with some of my 3D geometry going missing after I have saved the drawing.  Running AutoCAD 2013, Saving file Format 2010.  I draw a room.  I have walls, chairs, desks, a floor, ect.  I save the drawing.  When going to re-open the file I can see all of my geometry in the file preview, but when opening the DWG the floor is missing.  All Layers are on and thawed.  When running a purge command it indicates that something is on the layer, but I can't see it or select it.  Changing visual styles also has no effect.  Are there any thoughts as to what is happening, how I can fix it, and how to avoid it in the future.  I have used CAD in 3D since CAD 2000 and have never had this issue.  Any input is appriciated.  Thank you.
Distinguished Mentor
darawork
Message 2 of 14 (301 Views)
Re: Lost 3D Geometry
02-07-2013 09:14 AM in reply to: radioflyer364
Did you try an 'AUDIT'..?
Hardware acceleration / viewport degradation settings?
Graphic card drivers / type?
System information: Win7 x64 / 3DSMax Design 2015 / AutoCad 2015 / Xeon E31225 quadcore @3.10Ghz / nVidia GTX760 2GB (337.88 Driver) / 24Gb Ram / Corsair 650w
GrantsPirate
Message 3 of 14 (292 Views)
02-07-2013 09:43 AM in reply to: radioflyer364
Maybe try 3DCLIP and turn front and back clipping off?  Right two icons in that window after starting 3DCLIP.
radioflyer364
Message 4 of 14 (284 Views)
02-07-2013 10:20 AM in reply to: darawork
ran an Audit, no objects were deleted.
ATI FirePro v4800 video card  This is a relativly low detail drawing so I don't think we are having card issues.  Also I have run it on 3 seperate machines of different set  ups and had the same results.
radioflyer364
Message 5 of 14 (282 Views)
02-07-2013 10:21 AM in reply to: GrantsPirate
No cameras of clippings have been created, So this is not an issue.
GrantsPirate
Message 6 of 14 (276 Views)
02-07-2013 10:29 AM in reply to: radioflyer364
We could guess all day or you could post the drawing or a small portion with the problem layer and it might get solved quickly.
JDMather
Message 7 of 14 (271 Views)
02-07-2013 10:58 AM in reply to: radioflyer364
You should be aware that this preview is a bitmap snapshot created automatically at some point and is not indicative of the actual geometry within the file.  In other words - it is a picture, not geometry.
Attach your file here.
I have had success recovering "lost" geometry like this using other CAD programs (but I haven't seen this problem in AutoCAD since v2010).  Edit - I see you saved to v2010.  Well you might be in luck if you attach the file here.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
radioflyer364
Message 8 of 14 (260 Views)
02-07-2013 11:36 AM in reply to: JDMather
I would love to send you yhr file, but it is too large to post.  Do you have an email I can send it to?  It is a 3meg file.
JDMather
Message 9 of 14 (255 Views)
02-07-2013 12:00 PM in reply to: radioflyer364
jmather_at_pct_dot_edu
or
the file limit is much larger over here http://w.augi.com
JDMather
Message 10 of 14 (246 Views)
02-07-2013 12:36 PM in reply to: JDMather
This is what I see in the file (in another CAD program).
Is there geometry in this image that is missing when you open in AutoCAD?
Edit: Never mind - just checked the Preview on the AutoCAD file.  I will try to dig a bit deeper and see if I can recover anything.
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
