AutoCAD 2013/2014/2015
bjackman
Message 1 of 9 (263 Views)
Lofting - Need Help!
263 Views, 8 Replies
01-30-2013 03:53 PM
Can anyone tell me if you can create a solid by lofting between two section, in this case they are 3d polylines,  along a given path. The path is at the top of the sections. Using the loft command  I have to key in the PO ( point ) option several times to get the path option to show then when I select the path it gets treated as another section. See attached. Thanks for the help. Brian
bj@suncoast
Patchy
Message 2 of 9 (254 Views)
Re: Lofting - Need Help!
01-30-2013 04:18 PM in reply to: bjackman
Sweep will, Loft won't
bjackman
Message 3 of 9 (231 Views)
01-30-2013 07:43 PM in reply to: Patchy
Hi Patchy, I appreciate the input. It looks like the sweep command created 2 solids over each other. The profiles are not the same and what i'm trying to draw tapers on all surfaces except the top from the larger section on one end to the smaller section at the other end. Brian
bj@suncoast
JDMather
Message 4 of 9 (226 Views)
01-30-2013 08:38 PM in reply to: bjackman
It appears to me that the two profiles are planar and should be 2D polylines rather than 3D polylines.
Then it becomes a question of the correct connection.
This would be much easier in Autodesk Inventor - do you have access to that program?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
bjackman
Message 5 of 9 (223 Views)
01-30-2013 09:00 PM in reply to: JDMather
Hi JD, If I change the sections to 2d polylines will this work with the lofting command? This is a tapered profile on all sides except the top with the curved path being the top of the section on both ends. Yes I do have inventor fusion that came with the 2013 Acad software but have never used it. Thanks for the input. Brian
bj@suncoast
JDMather
Message 6 of 9 (201 Views)
01-31-2013 07:58 AM in reply to: bjackman
I know it will work in Autodesk Inventor.
AutoCAD can be finicky with Guides/Paths, but I'm guessing it can be done in AutoCAD too.
I will try to find time to run the Inventor solution first.
I am a little concerned about your true design intent though.
Usually with something like this the profile is made perpendicular to the start/end of the path.
I'll try to do it both ways and let you decide.
bjackman
Message 7 of 9 (195 Views)
01-31-2013 08:26 AM in reply to: JDMather
Perpindicular to the path at the ends is what I'm looking for, thanks for the help. Brian
bj@suncoast
JDMather
Message 8 of 9 (180 Views)
01-31-2013 10:33 AM in reply to: bjackman
Use the UCS ZAxis Object option to set your ucs perpendicular to the end(s) of the path before creating the profile.
bjackman
Message 9 of 9 (176 Views)
01-31-2013 10:40 AM in reply to: bjackman
Accepted as solution. Thanks Brian
bj@suncoast
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
