AutoCAD Forum
Locked Viewport scaling
9 REPLIES 9
Message 1 of 10
rafaljt
883 Views, 9 Replies
This is my first post here, I always tried my best and did anything alone. But this thing drives me crazy and i cant find the solution.
In my drawing layout nr. 2 has blocked viewports. The button on bottom right is dark grey and doesn't work. And standard "Zoom nXP" command doesn't help either.
First layout works well with scale. But I cant change plotter to HP HP7685 as our teacher wants us to. Gives some communicate with rastric drawing.
I attach my file below.
Please help me, this thing is killing me:)
9 REPLIES 9
Message 2 of 10
Alfred.NESWADBA
in reply to: rafaljt
Layout2 has not any locked viewport, if you select the viewports do you really see them as locked?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Message 3 of 10
rafaljt
in reply to: Alfred.NESWADBA
No, ofc not. It would be too simple. But try to scale it anyway. Scaling doesnt work
this viewport button is somehow locked, dont know why
Message 4 of 10
Alfred.NESWADBA
you are aware that these viewports are all set to perspective? Perspective views can't have a "scale" ... is that what you are looking for?
- alfred -
Alfred NESWADBA
Message 5 of 10
rafaljt
Theres something new to me.. continue pls.
Message 6 of 10
Alfred.NESWADBA
For perspective views you can't define a plot scale, is not possible at all (look to the screenshot, you see one dimension has different sized depending on position (front/back) of a geometry).
I'm not sure what you mean by "continue pls", wasn't that the answer why setting a scale does not work?
- alfred -
Alfred NESWADBA
Message 7 of 10
rafaljt
I mean how to change it to normal scaled view so i can scale it as i should. I'm sorry for asking newbie questions.
Message 8 of 10
Alfred.NESWADBA
Ok, you can use the viewcube-icon (looking like a small house in the upper-left corner of the viewcube ==> right-click and select "Parallel".
You can also use the command _VIEW, in that dialog change the property "Perspective" to OFF.
- alfred -
Alfred NESWADBA
Message 9 of 10
rafaljt
Vielen Dank fur Seine Hilfe!
(sry for my german if sth wrong)
You really helped me! Thanks a lot
Message 10 of 10
Alfred.NESWADBA
You are very welcome!
- alfred -
Alfred NESWADBA
”Boost
