Need help.I am facing an issue which I need to reload my profile setting every time I open a new file. Any way solve it?
The shortcut your using to start your AutoCAD probably has a default profile name to open with. This could require you to change to your profile each time. Check the properties of the shortcut your using to start AutoCAD, look at the text entered for the "Target". If you see the command switch "/p" then it's setting the startup profile. Simply remove this to start ACAD with the most recent profile you closed the application with, or change the text to read as the profile you'd like to load.
Hope this helps
