AutoCAD Forum
LiveUpdateFrame.htm will not display
1 REPLY 1
349 Views, 1 Reply
Hi!
We have a problem with one install of AutoCAD 2013.  When I try to download and install an available update, a browser window opens up and tries to display the local LiveUpdateFrame.htm file.  The browser stays blank and the update does not go forward.  Any help will be greatly appreciated.
I am trying with IE 10 and Chrome, but no one works.
Thanks!
P.D.: I have a student licence.
Hola!
Tengo un problema cuando trato de instalar la actualización LiveUpdateFrame.htm. Cuando hago click en instalar, se me abre una ventana y trata de conectarse con el disco local (C), y el buscador queda vacio y la actualización no se puede ver. Estoy probando con IE 10 y Chrome y ninguno funciona. Mi licencia es de estudiante.
Muchas gracias por la ayuda!
1 REPLY 1
jggerth
I would recommend that you simply go to the Autodesk website, find the update you are after, and manually download and install.    Rather than wasting time/energy on a liveupdate mechanism that seems to be problematic.
”Boost
