Now that I have used Mechanical 2015 for a few days, and have attempted to solve these issues myself, I find I need to ask for help, since I am in no way an Autocad guru. I would like to fix the following behavior:
1) I use solids that are made up of multiple, non-contiguous solids, such as our method for showing a threaded hole is a through hole at the nominal OD, and a suspended cylinder of the minor diameter inside the hole, unioned together.In previous versions of Autocad, when I sliced this solid, I got two pieces, one on either side of the slicing plane, or everything to one side of the slicing plane if I so choose. In 2015, when I slice a solid made of multiple parts, it does an unwanted separate on the remaining solid, so I am left with all those little thread ID cylinders hanging in space as separate solids. Why does it do this? Is there a variable I am missing to fix this behavior?
2) When I draw a line in space, it does not show the elastic band from my starting point to my pointer any more, but it does show other 2D entities like circles and plylines as I draw them. With lines, it shows nothing, so I have no graphic representation of the line I am trying to draw. If I turn on dynamic input mode, it shows the line, but I do not like that mode. I just want my old elastic band back. I was wondering if I just have the elastic band color set to black, which is also my background color.
3) When I copy or move an entity (solid or 2D), the elastic band from the base point to my pointer is now an orange hidden line. I don't like it and want to change it to the way it was. Also, if I happen to be moving or copying a solid, it is very slow to draw the solid on my pointer as I drag. This is the same in dragmode on or auto.
4) Highlighting selected entities, especially solids. Instead of the easily seen dotted line highlighting, it is now a barely perceptible blue glow on the solid edges, or no highlighting at all on 2D entities.This makes it hard to tell if the part is selected, or just blue. Is this able to be changed back to the old highlight?
#2 When I first installed AutoCAD2015, I too had no "rubber band" connecting the start point and the cursor. I don't know when/what changed, but It's not doing it now?
#3 I beleive the Move/Copy rubberband color was tied to another display element in 2014 and previous, but it seems to be independant and non-configurable in 2015 as far as I can tell
#4 I see you've resolved that, but I wonder why it's no longer on the Visual Effects settings in Options? In previous versions, there was a graphical dialog that let you choose between dashed, thickened, or both, as well as whether solid textures were highlighted... now it seem to be controlled only by an obscure sysvar.
Unless I misunderstand the problem, I'm not experiencing the separation of non-contiguous objects after SLICE. Could these objects be something other than a single AutoCAD solid. A "group" of solids, or an AutoCAD Mechanical AEC object? I'd be happy to have a look if you want to attach a sample drawing, but since I don't have Mechanical, I still might not see the same results.
If you are using the UNION command then you are just filling in the hole with the minor diameter object no? I can not replicate what you describing in either 2014 or 2015. Are you using SOLIDHIST 1 perhaps?
Well that is weird.. I get the same thing here.
You also can't crtl + click a solid feature to remove it from a selection. And slots or slotted features have not been able to stretch since AutoCAD 2013. Every release is a lesson in finding work-arounds to some pretty odd behaivors.
Fhof, I think you've come up with Autodesk's company motto.
"Every release is a lesson in finding work-arounds to some pretty odd behaivors."
"Ain't that a shame"
Kim
Thank you for taking the time to bring attention to the SLICE issue by so clearly articulating it. I am also affected by this issue.
We use Autocad for solid modelling of cut stone masonry assemblies such as building veneers, both simple and ornate, as well as monuments and other custom applications. When modelling we choose not to model the mortar joints in between the masonry units. They are simply implied by the voids in between the solid model masonry units. As a result we too use "solids that are made up of multiple, non-contiguous solids". When designing mortar joint locations and cut stone unit sizes it is necessary to modify the model at both the overall global level as well as the individual unit level depending on what you wish to accomplish. This involves frequent use of UNION and SEPARATE on the model.
The new and unexpected behaviour of the SLICE command on "solids that are made up of multiple, non-contiguous solids" as you have so eloquently described is a hindrance to using the solid model for our purposes. Until the behaviour of the SLICE command is corrected to provide logical expected results we will need to return to using Autocad 2014. I have made some attempt to find some logic behind the results obtained when using SLICE in Autocad 2015 however when dealing with more convoluted assemblies such as a stone cladding for a multilevel staircase the results obtained make the software not worth the effort of using when the previous release provides fully functional solution. This in itself is not so bad until you consider that the subscription is providing no additional value to multiple users when you have made the choice to revert to the previous version.
I know that the way that we use Autocad in our office is a bit unconventional and probably not the norm however I would really feel let down if this issue is not addressed by or before the next release by either fixing the command to perform as expected or explaining the "new rules" on how to use the command to obtain expected results.
Hello All,
I don't know when it happened but it appears that this issue has been corrected - must have been part of an update.
Thanks!
