Solved by abubakars. Go to Solution.
Solved by Ajilal.Vijayan. Go to Solution.
what´s with sheetset ?
http://docs.autodesk.com/ACD/2011/ENU/filesACR/WS1a9193826455f5ffa23ce210c4a30acaf-53a1.htm
cu cw
If the 'Dwg No, Revision, Title as in layouts' are in title block attributes, use DATAEXTRACTION to extract these datas from the drawings.
And create an AutoCAD table or spreadsheet.
Try with free BatchInDatabase or BatchInEditor tools to create drawing list in CSV format and insert them as table in AutoCAD.
See the video of Attribute extraction in action: http://www.youtube.com/watch?v=_9o7pox2vOw
Are you asking for a sample file to test this tool?, you can try with your own attribute block or create a new one which could be done within few minutes of time.
