Solved by hmsilva. Go to Solution.
Solved by dbroad. Go to Solution.
If the system variable, attdia is set to 0, then an insert command including attribute entry is just:
(command "_.-insert" "yourblocknameincludingpath" <insertionpoint> <xscale> <yscale> <rotation angle> <attribute 1>...<attribute n>)
Of course whether 2 scale factors are required depends on the block's setting for uniform scale.
Paths are best entered with slashes instead of backslashes since the backslash is an escape character in lisp.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
