I created a base file and xref'ed the file in to a sheet file.
The linetype in the base file is a dashed line but shows up as a centerline in the sheet file.
When I try to "edit the reference in place" in the sheet file the linetype shows up properly, but then reverts back to the (incorrect) "centerline" when I save the xref in place.
I've checked all the layer linetypes in the sheet file; they are set properly.
I've checked the visretain settings.
I've detached and re-attached.
The dashed line shows up properly in all the other files that it is xref'ed in to, so I'm assuming it's a setting in this particular sheet file. Either that or a corrupt file?
I cannot figure out what is going on.
