Please HELP!!
Very new to this, Help very much appreciated
We recently bought CAD 2014 (a week ago, new, not upgrade). We have been working on DRAFTSIGHT previously. Having a major problem opening drawings in 2014. A drawing that was workable yesterday, wont open at all today. Does not happen all the time, but once the drawing 'disappears' it stays un-openable even on other PCs. It still opens in DRAFTSIGHT, but hey, we would like to move on. (New server also installed, maybe teething problems?) (We are a small company) Recover does not work, saving or moving to Desktop does not work either. Not using + tab and even 'reset to default', but, alas, still no joy.
Anybody?
Could you please post that drawing here so I could have a look at it?
Hi JoAnn,
Thanks for the quick response. Hope i'm doing this right. Please see attached.
Kind regards
Hello from France
Welcome on the Autodesk/AutoCAD Forums !
1) Please could you try to open your DWGs in RECOVER Mode ?
2) Which Windows exactly : Win XP Pro, Win Seven, Win 8.0, Win 8.1 ??
and version 32 or 64 bits ?
3) How many Ram on your PC : 2 / 3 / 4 / 6 / 8 / etc Gb ?
Bye, Pat
PS: I don't see your attached DWG, so please attach it in ZIP format !
Patrice BRAUD
Hi Pat,
1. Tried recover. It goes through the motions, but still no drawing. (No error messages either, just blank)
2. Windows 7
3. Not a clue 🙂 will find out
Attached zip. Not much smaller. Are the drawing files maybe too big? (The drawings opened fine yesterday)
Thanks for response,
Ami
Hello
I have tried to open your DWG in Recover Mode with MAP 2014 & MAP 2013
- No Error
- I see nothing
So it is strange ...
Have you tried to save in DXF format from Drafsight and try to load the DXF file from ACAD ?
Bye, Pat
Patrice BRAUD
Please see attachment. I can see there is data in the drawing but it doesnt open it at all. I think you should submit your drawing to Autodesk themselfs and see if they can recover it
Sorry forgot the attachment
Hello
An other idea ...
Have you tried to save from Drafsight in an OLD DWG/DXF format : 2007 / 2004 / 2000 / R14 ???
Which format Drafsight can write ???
Bye, Pat
Patrice BRAUD
Hello
Ah, Ah, so in fact your DXF (or DWG) generated by Drafsight, is incorrect !
And ACAD can recover (or open) it ... but something is wrong !!
Bye, Pat
Patrice BRAUD
You know what they will say: source from Draftsight is the problem and refer you back to the source.
I opened your file in DraftSight, purged it, saved it to R14 format, it seems to open just fine in AutoCAD 2012-2014 now, model space and the single paperspace layout are well populated with content. See attached.
