Issue : we couldn’t invoke AutoCAD 2014 from our server by using visual basic programming.
The same program(code) can invoke AutoCAD 2000i without any issues.
We will receive an error message like “ActiveX component can’t create an object”, when we try to open AutoCAD from Visual basic 6.0 program.
We are using the following code for open AutoCAD.
Public Sub ConnectToAutoCad()
On Error Resume Next
Set Acad = GetObject(, AUTOCAD_VERSION)
If Err Then
Err.Clear
Set Acad = CreateObject(AUTOCAD_VERSION)
Sleep (2000)
If Err Then
MsgBox Err.Description
Exit Sub
End If
End If
Acad.Application.Visible = True
End Sub
Operating system : windows server 2003
AutoCAD :AutoCAD 2014 with 32 bit
Visual basic 6.0 is used to invoke the autocad 2014 .
Please help me to resolve this issue ASAP.
You have AutoCAD installed on the server and you're trying to open it from a workstation?
No. we are access the AutoCAD from the server itself. We don't have any issue in opening AutoCAD 2014 manually in server. But opening the AutoCAD 2014 through programmatically has an issue.
Did this ever get resolved ? I am upgrading a project that worked in Acad 2010 with very similar code. . The error message talkes about an invalid cast of object type
System.__ComObject
I have this code working on a test virtual machine running in my development environment. That machine is a 32bit workstation. The final location will be on a 64 bit 2008 R2 SP1 server
Public Sub New(ByVal strAcadVersion As String) Try If Len(strAcadVersion) > 0 Then _AcadVersion = strAcadVersion End If 'get existing 2007 _App = GetActiveObject(_AcadVersion) _AppStarted = True Catch Try 'create 2007 _App = CreateObject(_AcadVersion) 'set started flag _AppStarted = True Catch ex As Exception _AppStarted = False HandledExceptionManager.ShowDialog( _ "Error Creating AcadApp", _ "Autocad control will not take place", _ "Verify that the correct version of Autocad is being used", _ ex, , , , True) Throw ex End Try End Try _PrintersAvailable = GetPC3Files() End Sub
The error message I am returned is :
Log Name: Application
Source: PDFPublisher.exe
Date: 9/26/2014 3:38:34 PM
Event ID: 0
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: Meridian2
Description:
What happened:
How this will affect the user:
What the user can do about it:
More information:
Detailed technical information follows:
Date and Time: 9/26/2014 3:38:34 PM
Machine Name: MERIDIAN2
IP Address: 131.243.130.76
Current User: Mzwijacz
Application Domain: PDFPublisher.exe
Assembly Codebase: file:///C:/Program Files (x86)/CDS/PDFPublisher/PDFPublisher.exe
Assembly Full Name: PDFPublisher, Version=2013.0.0.2, Culture=neutral, PublicKeyToken=null
Assembly Version: 2013.0.0.2
Assembly Build Date: 9/26/2014 12:37:16 PM
Exception Source: CDS.AppControler
Exception Type: System.InvalidCastException
Exception Message: Unable to cast COM object of type 'System.__ComObject' to interface type 'Autodesk.AutoCAD.Interop.AcadApplication'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{7558007D-8677-4FF1-BD48-B66281BD3DD7}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
Exception Target Site: .ctor
---- Stack Trace ----
CDS.AppControler.AcadApp..ctor(strAcadVersion As String)
AcadApp.vb: line 0314, col 17, IL 0151
