AutoCAD Forum
Is there a way to go back to Normal Text
9 REPLIES 9
Message 1 of 10
zzz144
724 Views, 9 Replies
The text gets skewed when some parts of the drawing get moved in Z direction.
I have looked everywhere for years for a solution to this... commands such as move everything to elveation 0...
nothing works. Once the text goes bazrck it never can be fixed.
OR Can it be fixed?
9 REPLIES 9
Message 2 of 10
braudpat
in reply to: zzz144
Hello from France
Not sure to well understand your problem !
Please could you give us an extract of your DWG (with Wblock) with red circles where there are problems !
and with DWG saved in a 3D view (or a 2D view if you have problem even in 2D Top view) ... so we can see the problem !?
Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 3 of 10
zzz144
in reply to: braudpat
Here's both versions....
Message 4 of 10
GTVic
in reply to: zzz144
This may not help but AutoCAD does have a bug where Arial text (or any TrueType font) inside a block will take on a bold appearance if the block is rotated. So if you have both regular text and attributes in the block then the text part looks distorted or bolded.
For that bug the only solution is to use a font like RomanS.shx or to use PRESET attributes in the block in place of regular text or to explode the block.
I would test to see if this happens with ROMANS.SHX.
Message 5 of 10
zzz144
in reply to: zzz144
Yeah... Can't use Romans or that kind of font.
Just checking because this has been happening since the 2000 release...
the only way it goes away is if I copy the drawing and paste it into a fresh sheet.
but that is a painful way of fixing things...
Message 6 of 10
braudpat
in reply to: zzz144
Hello
YES if you insert the bad DWG in a blank DWG : no problem !
Bye, Pat
Patrice BRAUD
Message 7 of 10
Patchy
in reply to: zzz144
Copy and paste the line below to your command line, press Enter , then Regen
(COMMAND  "._dview" "ALL" "" "points" "0,0,0" "0,0,1" "exit" ) (princ)
Message 8 of 10
braudpat
in reply to: Patchy
Hello Patchy
EXCELLENT !
I have checked "_VPOINT" (and "_VSCURRENT") but NOT "_DVIEW" !!
Bravissimo, Bye, Pat
Patrice BRAUD
Message 9 of 10
zzz144
in reply to: Patchy
THX Patchy!!!!!!!!!!!!
Message 10 of 10
GTVic
So the method of moving in the z direction is somehow altering the display to a perspective view?
”Boost
