The text gets skewed when some parts of the drawing get moved in Z direction.
I have looked everywhere for years for a solution to this... commands such as move everything to elveation 0...
nothing works. Once the text goes bazrck it never can be fixed.
OR Can it be fixed?
Thank you!
Solved by Patchy. Go to Solution.
Hello from France
Not sure to well understand your problem !
Please could you give us an extract of your DWG (with Wblock) with red circles where there are problems !
and with DWG saved in a 3D view (or a 2D view if you have problem even in 2D Top view) ... so we can see the problem !?
Bye, Pat
Patrice BRAUD
Yeah... Can't use Romans or that kind of font.
Just checking because this has been happening since the 2000 release...
the only way it goes away is if I copy the drawing and paste it into a fresh sheet.
but that is a painful way of fixing things...
Hello
YES if you insert the bad DWG in a blank DWG : no problem !
Bye, Pat
Patrice BRAUD
Copy and paste the line below to your command line, press Enter , then Regen
(COMMAND "._dview" "ALL" "" "points" "0,0,0" "0,0,1" "exit" ) (princ)
Hello Patchy
EXCELLENT !
I have checked "_VPOINT" (and "_VSCURRENT") but NOT "_DVIEW" !!
Bravissimo, Bye, Pat
Patrice BRAUD
