I have a drawing that converted from Microstation, i believed, and the viewport is invisible. I have thaw and turn on all layers, but still not see the viewport outline. Any ideas why the viewport is invisible?
Thank you!
Dennis.
Solved by Patchy. Go to Solution.
Type PSPACE at the command line and see if anything changes while in a layout or AutoCAD reports something.
Repeat after that with MSPACE command.
Get AutoCAd to tell you instead of just guessing 🙂
Dean,
Nothing happened after PSPACE or MSPACE. Attached is the file. Could you please take a look!
I already did and posted the drawing with the viewport shown.
Go see here for the autolisp:
I converted MS to Autocad but have not seen a viewport come from MS.
Ask the author to solve the viewport problem if they are familiar with Autocad, if not run the autolisp and keep on trucking.
