AutoCAD Forum
Installation
5 REPLIES 5
VirginiaJane
290 Views, 5 Replies
Installation
Hi
I am having trouble installing Autocad 2014 even though the system requirements all seem to be fine and I have tried switching off my antivirus security programme firewall.  I can get it to download the software but just as it says the software is downloaded 100% and before I can install it, it says it is running a security scan .
At this stage it comes up with a message saying connection interrupted as a result of 3 possible issues.
1) Installation package moved from installation location which is not supported.
2) Autodesk download website was closed or manually refreshed before the installation was lauched.
3) A firewall has blocked the network ports.
Can anyone help ?  What am I missing here?
Many thanks
Ginny
5 REPLIES 5
braudpat
in reply to: VirginiaJane
Hello
Welcome to the Autodesk/AutoCAD Forums !
A few questions
- Which Windows exactly ? Win XP Pro , Win Seven , Win 8.0 , Win 8.1 ?
- Have you downloaded the entire file before trying to install ?
- Version 32 or 64 bits ?
Have you retry to download the entire file ? (to compare the size of the files) ?
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
VirginiaJane
in reply to: braudpat
Hi
In answer to your questions.
Windows 7 Home Premium
Yes have downloaded 100% but not been able to install
Version 32 bits
Ginny
pendean
JDMather
@VirginiaJane wrote:
Version 32 bits
Ginny
Windows 7 32-bit version is very very rare OS, on old old computer, typically installed by YOU on very old computer.  Are you sure you are running 32-bit OS?
Go to Start and right click on Computer and select Properties.
Post screen shot of you OS properties here.
I'm betting that it will report that your OS is actually 64-bit, not 32-bit.
JDMather
in reply to: JDMather
Did you verify that your OS is 32-bit?
See this image for example from two of my computers.
”Boost
