AutoCAD 2013/2014/2015
Distinguished Contributor
RNDPIS
Message 1 of 9 (1,273 Views)
Installation Problem
1273 Views, 8 Replies
10-06-2012 04:18 AM
We have faced  a problem when we installed AutoCAD 2013. The same problem is occoured when we installed Navis 2013 and also Revit 2013.
Our machine is:
  1. 64Bit XP
  2. Vista
  3. Windows 7
The error code are given below:
Failed Installation aborted, Result=1603
Failed    Failure is ignored, Result=1619
Failed    Installation aborted, Result=53
We have gone through the link (http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10310469&linkID=9240617) but we can't installed. Please help us.
Alfred.NESWADBA
Message 2 of 9 (1,267 Views)
Re: Installation Problem
10-06-2012 04:34 AM in reply to: RNDPIS
Do you have multiple workstations to install and none of them does install or some of them don't run the installation? Or what is the reason that you listed 3 different operating systems?
At least Vista is not supported for 2013 releases!
1603 is most often a problem when you have not all rights and/or some defending program is active (like antivirus).
The next message "Failure is ignored, Result=1619" is not an error, it tells you that it had a problem, but "is ignored"!
It is also important that you handle product by product. We don't know currently what error message you got for what product and what operating-system
- alfred -
Alfred NESWADBA
RNDPIS
Message 3 of 9 (1,263 Views)
10-06-2012 05:15 AM in reply to: RNDPIS
Thanks for your quick response.
We have used 64 BIt XP machine and have isntalled AutoCAD2013. Theh the error message "Failed    Installation aborted, Result=53" is shown and stop the installation process.  We are in a big problem. Please suggect.
Alfred.NESWADBA
Message 4 of 9 (1,260 Views)
10-06-2012 05:19 AM in reply to: RNDPIS
as you may have searched also I don't find AutoCAD and the installation error "53". Can you upload the full log-file?
- alfred -
Alfred NESWADBA
RNDPIS
Message 5 of 9 (1,254 Views)
10-06-2012 05:53 AM in reply to: Alfred.NESWADBA
I have attached the log file for your review.
Thanks.
Alfred.NESWADBA
Message 6 of 9 (1,239 Views)
10-06-2012 06:10 AM in reply to: RNDPIS
two steps I would try now:
  • a) copy the installation media to your local drive, don't start it from a network-share.
  • b) uninstall Framework 4 on your system, then reinstall it manually (download it e.g. from >>>here<<<, but take care of the language if yours is not english). After installing that let Windows do it's updates
  • c) try again to install AutoCAD now from the local copy of the setup
Good luck, - alfred -
Alfred NESWADBA
Alfred.NESWADBA
Message 7 of 9 (1,238 Views)
10-06-2012 06:13 AM in reply to: RNDPIS
one more question: is that started from a network install-package? The log file is so small, I have not had it seen so small yet.
So it may be that the installation-package is not ready for WinXP64 (as this os is I think the one that is used only rarely). In that case try to install from the original AutoCAD-install media and not from the prepared network-setup.
That's just a guess.
- alfred -
Alfred NESWADBA
RNDPIS
Message 8 of 9 (1,216 Views)
10-08-2012 06:03 AM in reply to: Alfred.NESWADBA
We have followed you mentioned step but we are still facing the problem. We have attacehed the log file an a snapshot for your reference.
Alfred.NESWADBA
Message 9 of 9 (1,209 Views)
10-08-2012 06:13 AM in reply to: RNDPIS
have you read that part within your log:
Your computer is using an unsupported version of the Microsoft .NET Framework. The product you are installing requires Microsoft .NET Framework 4.0 or later.
Please update .NET Framework 4.0 and restart your computer before installing your Autodesk product.2012/10/8:14:10:03	administrator	DTP123456	=== Setup ended ===
So if you have installed 4.5, then remove it.
If you have installed version 4 then I would remove it (including any updates or languagepacks that might have been installed by Windows-update.
Then install FW4 again, let Windows update then your system. I think that is the most clean sitation around Framework, so an additional start of AutoCAD-installation could be done then.
[EDIT]: and please don't install from a network source (if it's not a prepared network-setup package), copy the installation-media to your local system and start it from your C: (not from 10.0.15.8) (/EDIT]
Alfred NESWADBA
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
