AutoCAD 2013/2014/2015
Distinguished Contributor
Message 1 of 4 (2,915 Views)
Accepted Solution
Install error AutoCAD 2013
2915 Views, 3 Replies
10-04-2012 01:56 PM
I get an installation error when installing 2013.
AutoCAD installs fine but it is the inventor component that hass an error.
I believe this is due to me having a newer version of Microsoft Visual C++, i require this for other software.
Does anyone have any suggestions, it wouldn't normally bother me but i get an annoying message telling me that AutoCAD hasn't been installed properly every time i start up.
The error is below:
2012/10/5:09:35:39 Geg GEG-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): D:\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Geg\AppData\Local\Temp\vcredist_x86_2005.log"" "
2012/10/5:09:35:46 Geg GEG-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
Creative Intentions
Win 7 Pro 64bit, Dell Precision M6500
*Expert Elite*
Alfred.NESWADBA
Message 2 of 4 (2,892 Views)
Re: Install error AutoCAD 2013
10-05-2012 10:57 PM in reply to: GegH1
I had a similar problem some time ago when Windows-update had updated the C++XXXX redistributable to a newer version than DesignReview (as part of the AutoCAD-installation) tried to install.
The solution was to uninstall the C++xxxx redistributables (including updates if there are any) and then start the installation again.
Good luck, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
Message 3 of 4 (2,884 Views)
10-06-2012 01:32 AM in reply to: Alfred.NESWADBA
The problem is i need c++ because i am building an application with visual studio.
Creative Intentions
*Expert Elite*
Alfred.NESWADBA
Message 4 of 4 (2,875 Views)
10-06-2012 04:06 AM in reply to: GegH1
You should just uninstall the redistributable! And when AutoCAD installed then successfully you can reinstall it again (if it's not already installed then by AutoCAD).
- alfred -
Alfred NESWADBA
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
