AutoCAD Forum
Insert multiple blocks using script
9 REPLIES 9
Message 1 of 10
sthompson1021
8945 Views, 9 Replies
Can anyone tell me whats wrong with this script? It inserts the first block and then quits. I had to change the the file to a txt to get it to upload
9 REPLIES 9
Message 2 of 10
You may only need 1 0 instead of 1 1 0 in your script, which defines the scale and rotation angle.
Also, do you need a minus sign "-" in front of your insert command? like so? -INSERT
*EDIT*  Try adding a leading space for the third line onwards.
Scott Wilcox, Edmonton, Alberta, Canada
AutoCAD 2014 Professional
Message 3 of 10
Thanks for the reply, unfortunately nothing worked.
I get this in the text window when it stops.
Message 4 of 10
After a lot of messing around, I found that I had to put in the block name after each set of coordinates. Also a kudo to scottwilcox as he was right about only needing 1 0 after the coordinates
Message 5 of 10
FYI, this worked on my AutoCAD 2011:
Message 6 of 10
Hey, it works on my 2014 too... I could have sworn I tried it like that but I must have had something different. Thanks for the info.
Message 7 of 10
in reply to: sthompson1021
If you have the information in excel you can copy this into a word document.  Save as plain txt, inserting line breaks.  Change the extension from txt to scr
Message 8 of 10
You need a space and then a then a carriage return after each line
Message 9 of 10
shiva.b2008
sir,
i have same problem faced
Message 10 of 10
cadffm
in reply to: shiva.b2008
The solution is the same..
But a better solution is to use the scale option of insert command.
If you insert a block, defined for 'scale uniformly' only, acad ask only one time for xyz-scale.
If not, acad ask for x and y scale.
- Sebastian -
”Boost
