When I insert a block it doesn't actually show up in my drawing. I am prompted to provide a location and am given the option to scale, etc, but when I complete the command the block isn't there. I have even searched for the block using QSELECT and searching for it by name, but it isn't there. I can insert this block in different drawings without issues. I have found, however, that if I insert it as exploded it will show up. Why can't I insert it as a block though?
The block in question is "rail diag". I just renamed the file and for some reason now it works... I have no idea why though. If you think you can figure out the what & why then please feel free to check out the file. Thanks.
Could run an Audit to see if it woul fix itself.
Command: audit
Fix any errors detected? [Yes/No] <N>: y
Auditing Header
Auditing Tables
Auditing Entities Pass 1
Pass 1 4000 objects auditedAcDbSortentsTable(8207)
Error for Entry (4034E,4031E) eDuplicateKey fixed
Error for Entry (40CB7,40341) eDuplicateKey fixed
Error for Entry (40348,40E11) eDuplicateKey fixed
Error for Entry (80208,85B17) eDuplicateKey fixed
Error for Entry (8020F,85B1D) eDuplicateKey fixed
Error for Entry (85B23,8021F) eDuplicateKey fixed
Error for Entry (85B29,80226) eDuplicateKey fixed
Error for Entry (8022D,85B2F) eDuplicateKey fixed
Error for Entry (85B3B,8023B) eDuplicateKey fixed
Error for Entry (80B02,85B4E) eDuplicateKey fixed
Error for Entry (80B06,885EA) eDuplicateKey fixed
Pass 1 5100 objects auditedAcDbPolyline(2412B) XData Handle Unknown
Null
Pass 1 63300 objects audited
Auditing Entities Pass 2
Pass 2 30600 objects auditedAcDbBlockReference(CE519) BTR Id invalid
AcDbBlockReference(CE519) could not be repaired. It will be Erased.
Pass 2 36400 objects auditedAcDbBlockReference(CFE88) BTR Id invalid
AcDbBlockReference(CFE88) could not be repaired. It will be Erased.
Pass 2 47900 objects auditedAcDbBlockReference(D6644) BTR Id invalid
AcDbBlockReference(D6644) could not be repaired. It will be Erased.
AcDbBlockReference(D6645) BTR Id invalid
AcDbBlockReference(D6645) could not be repaired. It will be Erased.
Pass 2 53700 objects auditedAcDbBlockReference(D9691) BTR Id invalid
AcDbBlockReference(D9691) could not be repaired. It will be Erased.
Pass 2 59500 objects auditedAcDbBlockReference(E2D60) BTR Id invalid
AcDbBlockReference(E2D60) could not be repaired. It will be Erased.
Pass 2 63300 objects audited
Auditing Blocks
950 Blocks audited
Total errors found 18 fixed 18
Erased 6 objects
It looks like the block is from vertical autocad (Architectural or any CAD others than plain Autocad because of the block names)
It doen't show up because you had disabled Show Proxy Objects in this drawing.
It shows on other drawings because you click on Show Proxy Objects.
