AutoCAD Forum
Importing .bmp image to AutocadLT and attaching to drawing
5 REPLIES 5
Wabtec_Tom
297 Views, 5 Replies
I am having a problem attaching an imported .bpm image to an AutocadLT drawing. It only seems to reference the original .bmp which is useless when I send drawing to someone else. What am I doing wrong?
5 REPLIES 5
justshutup
in reply to: Wabtec_Tom
You can always ETRANSMIT your dwg to the recipient,  that way all of the associated files go along with the dwg.
Wabtec_Tom
in reply to: justshutup
OK.....
What is Etransmit? How or where is it explaned?
Tom Roth
Engineering Support, Kansas City
Wabtec Global Services
4800 Deramus Ave
Kansas City, MO 64120
816-245-5488
This email and any attachments are only for use by the intended recipient(s) and may contain legally privileged, confidential, proprietary or otherwise private information. Any unauthorized use, reproduction, dissemination, distribution or other disclosure of the contents of this e-mail or its attachments is strictly prohibited. If you have received this email in error, please notify the sender immediately and delete the original.
justshutup
In help.  Or google.
Wabtec_Tom
I found the Etransmit doc, not quite what I needed......
Ended up saving drawing as  a .pdf and sending out. Worked out OK in the end.
I do appreciate the help, I've got a lot yet to learn!
pendean
”Boost
