I am having a problem attaching an imported .bpm image to an AutocadLT drawing. It only seems to reference the original .bmp which is useless when I send drawing to someone else. What am I doing wrong?
@Wabtec_Tom wrote:I am having a problem attaching an imported .bpm image to an AutocadLT drawing. It only seems to reference the original .bmp which is useless when I send drawing to someone else. What am I doing wrong?
You can always ETRANSMIT your dwg to the recipient, that way all of the associated files go along with the dwg.
I found the Etransmit doc, not quite what I needed......
Ended up saving drawing as a .pdf and sending out. Worked out OK in the end.
I do appreciate the help, I've got a lot yet to learn!
