I am importing solidworks assembly files into AutoCAD 2014. They show up fine after importing them. It says the assembly is in inches but when i go into the individual parts blocks they are all 25.4 scale. Is there a way to not have all the parts scaled up when it is imported?
Start with a blank drawing, UNITS and pick Architectural, import your solidwork.
Your .DWT you use make a difference.
I can't test it here, so this may be a long shot, but explore the settings (hint: unitless) in the sysvars: INSUNITS, INSUNITSDEFSOURCE, & INSUNITSDEFTARGET.
INSUNITS is mentioned in the help file for importing SolidWorks parts/assemblies.
2.54cm = 1"
