AutoCAD 2013/2014/2015
Message 1 of 3 (5,328 Views)
Accepted Solution
Importing Google Earth Image
5328 Views, 2 Replies
08-09-2012 05:24 AM
Good morning everyone,
I just installed 2013 on my pc yesterday.  The first task I was given was to import a Google Earth image into AutoCAD to try to get some dimensions on a house for an exhibit.  I open Google Earth and set my location to import, then I go to the Render tab, select Set Location, I click Import the current location from Google Earth, click Continuethen i get an error message saying Class not registered.  Is there something i'm missing? I followed the directions given in help step by step, but it isn't working.  Any help or suggestions you could give would be greatly appreciated.  Thanks!
Brian
*Expert Elite*
pendean
Message 2 of 3 (5,316 Views)
Re: Importing Google Earth Image
08-09-2012 06:05 AM in reply to: bcasper
Are you using plain AutoCAD 2013 (where you are posting), or a vertical like Civil 3D (where you should be posting)?
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Google-Earth-utilities-with-R2013-products/td-p/34014...
The Google Earth add-ons for plain AutoCAD died due to Google licensing changes and there is no replacement.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Valued Mentor
TerryDotson
Message 3 of 3 (5,297 Views)
08-09-2012 10:42 AM in reply to: bcasper
Assuming your drawing has a known coordinate system, MapWorks Base can place the Google Earth image into your drawing at the proper location, scale and rotation.  Works in any full AutoCAD based product (2007 or higher).
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
