AutoCAD Forum
Importing DGN into Autocad 2015 is not keeping all the text
3 REPLIES 3
treed
951 Views, 3 Replies
Testing out the 2015 for Autocad and simply trying to import in a Microstation .dgn titleblock with text. It keeps blocks, shapes, etc... But it is not translating the text over. Has anyone had this issue? I can import the same drawing into 2013 and everything including the text shows up fine. I do have the same settings shown in both file import boxes, so am a little shocked as to why it may be having this issue.
3 REPLIES 3
pendean
in reply to: treed
Was there an error from AutoCAD? There usually is one. If not, report this difficiency to Autodesk http://usa.autodesk.com/adsk/servlet/item?id=1073063&siteID=123112
treed
in reply to: pendean
No error. In all regards it 'imported' just like anything else. Just
didn't keep all the text with it. Double-checked my seed files,
everything was the same. Just imported differently in 2015.
Tricia
This message was scanned by Barracuda
Spam & Virus Firewall 300.
christina.davis
in reply to: treed
Hi treed,
Can you please post the dgn file? I have not been able to reproduce this with any dgn files I have. You may also want to try toggling  "Explode text nodes to text elements" in the lower left corner of the Import DGN dialog box.
Thanks 🙂
Please hit the Accept as Solution button if my post resolves your issue.
Christina Davis
Technical Support Specialist
Frontline Technical Support
”Boost
