Hi to you all
I work with AutoCAD civil 3d as AutoCad 2014 and I'm trying to import a step file.
Thing is that I don't have step file as an option in my import file window.
So, what do I do?
Civil is all I have, it wasn't too importante anyway.
Thanks to all good people here, I can always count on you.
Have a nice day
Civil runs on top of vanilla.
You can start as plain jain vanilla AutoCAD.
I realize this is an old post but I was having same problem with autocad Civil 3d 2014. I was hoping the vanilla version would work but the .stp is still not showing in list either.
Thanks for your help though!
I think if you use OPTIONS, go to Profile Tab, there should be plain autocad that you can use.
(From memory, I'm not sure)
1st of all, I think it would be better to post your question in civil forum (I am with AutoCAD Mechanical version).
However, I have tried in my AutoCAD plain version (2014) and it confirmed JDMather's explanation. I have also tried to have a look in online help for Civil but found no way to get in as I don't have Civil version (I may be wrong). BTW, there is an import step file command "stepin" in Mech. You may give a look in Civil if there is a same command.
HTH
Hi all,
I have a problem with Auto Cad Mechanical 2018 opening the step-files. Auto Cad will not show an option for opening the file. I am also not able to open any other file by option "Open". With other words he doesn't want to search for the files. He only shows me the option that is presented on the picture below.
Thank you for the answer
Robert
