I guess you are speaking about AutoCAD Mechanical? If so >>>there<<< is the forum for Mechanical ... and verify that you have started with the Mechanical profile and not with the vanilla one.
- alfred -
>> but what do you mean by start with mechanical profile
AutoCAD Mechanical is installed with two profiles, one that includes the Mech-functionality and another one (Vanilla) that only does the plain AutoCAD work.
So verify that the Mechanical part is active in your working profile, otherwise there might be issues when you open drawings containing Mech-parts, but you can't work with them because of the wrong profile.
>> Should I delete mine and make a new one?
No, don't delete yours, just search in the Windows start menu for the icon that starts Mechanical with it's original profile (hopfully you have not overwritten the original one).
Good luck, - alfred -
>> the acadmpp.arg file is there
Again, I'm no Mech-user, but as far as I know the AutoCAD environment from other verticals Autodesk does not create an ARG-file after a fresh install of AutoCAD (and verticals). That might be different for Mechanical and I just don't know that?
At least: if you start AutoCAD with your profile, do the mechanical-specific commands work or not, that is the shortest way to verify what type of profile is active.
- alfred -
