AutoCAD Forum
I have a menu loaded - need the menu File
2 REPLIES 2
zzz144
224 Views, 2 Replies
Years ago i built a menu for autocad
I have all the components and blocks and in the options i have the path added and the menu works (i use menulaod and load the Menu.cuix file and it works)
But i need the .mnu file which i deleted by accident - so i can edit the menu.
I cannot read the .cuix file and make changes to it - its all giberish in notepad.
Please help.
2 REPLIES 2
maxim_k
in reply to: zzz144
You can do all changes to your custom menu via CUI command. But if you really need to see the contents of .CUIX. file, you can change .CUIX extension to .ZIP and extract resulting archive. All custom menu related files are inside this archive.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
pendean
in reply to: zzz144
Your old methods died many moons ago.
If you lost all of your MNU and MNS file, learn the new system, notepad editing is dead with the CUIx files:
http://www.cad-notes.com/2012/02/exploring-autocad-cui-creating-a-command-part-2/
”Boost
