AutoCAD Forum
How to set user coordinate to always start in last snap point?
6 REPLIES 6
1277 Views, 6 Replies
Before when I was creating models the origin (0,0,0) was always set in the snap point i started the line in. Now suddenly something happend and now 0,0,0 is always starting in the Original XYZ point.
How do I get back to the old settings?
// Fredrik
6 REPLIES 6
dmfrazier
Maybe what you are describing has to do with the UCSFOLLOW variable setting (but I may have mis-understood what you have described).
If this isn't it, can you please try to illustrate this issue?  Or maybe explain it in some other way?
Maybe you are right, but I didn't succed with UCSfollow either.
See attached picture:
If i like to start a line in point 2, I could do that earlier by snapping. Then i could type in lengh of the new lin: example 1500,0,0. Then the line was starting in point 2 and ended 1500mm away in X direction.
Now it starts in point 2 to but ends up 1500mm away from point 1 (in X direction from point 1).
I don't know what i have changed?
dmfrazier
That's something entirely different!
It sounds like you're describing the difference between absolute and relative coordinate entry.
Check the setting of DYNPICOORDS.
http://docs.autodesk.com/ACD/2013/ENU/files/GUID-87D649DF-8474-4F55-806E-604906030B36.htm
This might also help:
http://docs.autodesk.com/ACD/2013/ENU/files/GUID-AE225073-2ECD-41CC-9B8A-61743E8CFBA9.htm
Hi
I didn't succeed with Dynpicoords or # or *. But it worked fine with @. Great!
But I have to add the @ for each line, how could i get it to be set forever?
// Fredrik
dmfrazier
The @ means "relative to the last point picked".
I assumed you are using Dynamic Input (DYNMODE = 1, 2, or 3).
I thought setting DYNPICOORDS = 0 means "relative" coordinate input is "automatic" or assumed (in other words, you can omit the @).
If you are not using Dynamic Input, then you will have to use the @.
Now it works perfect!!!
DYNMOD was set wrong. I changed it to 1.
THANKS!
// Fredrik
”Boost
