I prefer to use "Realistic" visual style.
Please see the attachment.
Thanks for your help.
Solved by nestly2. Go to Solution.
In the Visual Styles manager (VISUALSTYLES), select "Realistic" then look under "Edge Settings" You can choose between Facet Edges, Isolines, and None. The number of Isolines is controlled by the ISOLINES variable, which by the way is 20 in your drawing... AutoCAD default is 4, so "someone" not only wanted those lines, they wanted 5x more than normally displayed 😉
(BTW, REGENALL may be required to update ISOLINES)
Very nice.
"In the Visual Styles manager (VISUALSTYLES), select "Realistic" then look under "Edge Settings" You can choose between Facet Edges, Isolines, and None."
Is this setting saved in drawing or in registry that makes every drawing with the same appearance?
Thanks.
ISOLINES is stored in the drawing, as are Visual Styles. Update your Template (.dwt) according to your preference.
Thanks.
