AutoCAD 2013/2014/2015
Member
Message 1 of 9 (2,811 Views)
How to reduce file size of my drawing..
2811 Views, 8 Replies
03-21-2013 04:39 AM
when i bind the xref's the file size is increasing up to 50mb. the size of the file before binding is 4.5mb. i tried all the options whic ppl given in the discussion here. purged(all regeapps,zero txts etc.),wblock even some lisps. but all in vain. even i tried to audit but it took 2hrs and nothing happened. this dwg containing only lines poly lines, blocks, txts etc. no images and not even dence hatches also. can any body help me out. because 1500 drawings like this. i have to submit the softcopy soon. please
*Expert Elite*
pendean
Message 2 of 9 (2,792 Views)
Re: How to reduce file size of my drawing..
03-21-2013 05:17 AM in reply to: thakkali27
How many xrefs in a file?
Size of each file/xref before attachment?
method of attachment?
plain AutoCAD content, or AEC content (from verticals like Civil ro Architecture etc.) in any of the files?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Member
Message 3 of 9 (2,784 Views)
03-21-2013 05:27 AM in reply to: pendean
it was attached not overlay.it is about 13 xref files, all are in different sizes, varies about 1mb to 5 mb..but now i've binded and all xref's are blocks.i could not find AEC objects in the drawings.
*Expert Elite*
pendean
Message 4 of 9 (2,782 Views)
03-21-2013 05:30 AM in reply to: thakkali27
>>>...now i've binded and all xref's are blocks...<<<
13files x 1-5MB = +/-50MB
Is there something I'm missing? The numbers seem to add up my friend.
Member
Message 5 of 9 (2,775 Views)
03-21-2013 05:43 AM in reply to: pendean
yes if u calculate like that, then thats correct. but one file i somehow managed to reduce to 8.5 MB.purge,audit, recover, convert to dxf and back..etc etc. the same procedure i tried to use for others.only few mb's are reducing.In some files it is showing AcDbDictionary 266MB. cannot save.and i can only save in 2013 format not in 2007 which client wants.
*Expert Elite*
pendean
Message 6 of 9 (2,768 Views)
03-21-2013 05:49 AM in reply to: thakkali27
While you wait for others to offer suggestions, I thought I'd let you know that when you get aorund to saving the file down to R2007 format the file will gain in size a noticeable percentage. R2013 has a significantly better compression that lower versions.
May I ask if your concern for a 50MB is due to the inability to email, or something else? And why you decided to bind all the files instead of simply leaving them as separate Xrefs?
Member
Message 7 of 9 (2,758 Views)
03-21-2013 06:35 AM in reply to: pendean
eventhough 2013 format is fine. but the file size is my main concern.client doesnt want xref's in the drawings, it is their instruction all the xref's must be binded.there are 1500+ drawings and its about 75GB!!! so they asked us to try for a reduced file size. thanks a lot for ur valuble help..
Member
Message 8 of 9 (2,724 Views)
03-23-2013 12:01 PM in reply to: thakkali27
Try to handle such large projects with Sheet sets.It is indeed very convenient for file management. And should decrease the file size too. All the best.
Sahaj
New Member
prashanth.mallige
Message 9 of 9 (2,709 Views)
03-24-2013 03:32 AM in reply to: thakkali27
I felt that, your all of Xref files have large annotative scales and some raster images. Anyway.
OPTION-1
1. Make sure you are using either metric or imperial.
2. In Option, User Preferences, reduce the default scale list. Apply, Ok.
3.Open your Xref file, In all of your Xref file, remove unnecessary annotative scales by SCALELISTEDIT and RESET.
4.Purge, Save and check drawing properties.
OPTION-2, there are some option by import and export from other applications like Revit,..etc  But I prefer to sort of issues from same application which are using.
FOLLOWED BY OPTION-1
1. Use Etransmit your main drawing first before binding.
2. Check drawing properties. If its reduce, then go for binding.
Please let me know, if its not worked out and if you have enough time to cleanup all of your Xref files, i will give you some solutions.
Best Regards
Prashanth Dhani
Prashanth Dhani
Sr-Structural CAD & BIM Engineer
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
