AutoCAD Forum
How to lock point cloud location without disabling cropping
1 REPLY 1
brian
2663 Views, 1 Reply
Is it possible to lock the location of a point cloud without disabling the ablity to use the cropping functions in AutoCAD 2015?  With the point cloud unlocked I keep inadvertently moving it somehow.
1 REPLY 1
christina.davis
in reply to: brian
Hi Brian,
If the point cloud is locked (even on a locked layer) the cropping functions won't work, but you can switch back and forth between locked and unlocked through the Properties palette (see attached image). Pick the point cloud, set Locked to No, crop, and then set Lock back to Yes.
I hope that helps.
Please hit the Accept as Solution button if my post resolves your issue.
Christina Davis
Technical Support Specialist
Frontline Technical Support
Autodesk, Inc.
”Boost
