AutoCAD Forum
How to export attributes of multiple blocks from multiple layouts ?
10 REPLIES 10
Message 1 of 11
limezestpizzawithextracheese
6104 Views, 10 Replies
Guys please, let me get this thing straight. I don't want to use external plugins, applets. All i want to do is to change some of the attributes of my blocks in each sheet that's all. I'm using only one block for each layout (sheet). So when i try to export attributes i see that i can't select blocks (objects) from multiple layouts.
So what is the solution to this. I'm planning to export attributes of my blocks from all the sheets and then i will open that txt file in excel to modify. At the end i will import those attributes back.
I can do this thing in model space but in paperspace in sheets, it is really frustrating. Someone please share a lean, easy to understand instruction.
Ps: Do not forget, not applet no add in, no plugin no script or autolisp if it's possible
Cheers.
Deniz
Deniz
10 REPLIES 10
Message 2 of 11
I understand you mentioned no add-ons, but I have to say the fastest way to do it is to use ATTOUT and ATTIN in Express Tools, which definitely / unfortunately are add-ons.
When it prompts to "Select objects:", just type "all" and it will select all blocks in both model space and paper space - includes all layouts.
Message 3 of 11
EDIT : IT WORKED //It simply does not work in Autocad 2013, i clicked express tools, then export attributes. Showed the txt file location to create, but after that when it asks objects to select, i type "all" simply nothing happened. It still waits to select objects. "_all" did not worked too.
Agh, my mistake. Sorry by "addon's, plugins" i meant the externally installed software or packs etc. Express Tools are built in, so it's ok for me to use. Thanks for the tip. And if i want to select all the blocks just in the paper spaces (layouts / sheets) ? Then what should i do ? Because when i have a drawing and lots of layouts it will select every block that is in the document. ( can i use filter or someting after hitting all ? )
Deniz
Message 4 of 11
Plugin / add-ons is to make your life easier, they do not mean to do harms in your drawing. Either "External" add-on or "Built-in" add-on are the same, they may have bugs but at the same time, save your time. Although there are some nasty add-ons make chaos but most of them are good and useful.
Back to the question:
You can set up a selection set with filter first, then pass it on to ATTOUT with "Previous" option when prompted to select objects:
Here is a simple example code to select all blocks in layouts only - again, it is an external add-on.
(sssetfirst nil
 (ssget "_X" '((0 . "INSERT")
	      (-4 . "<NOT")
	      (410 . "Model")
	      (-4 . "NOT>")
Message 5 of 11
OP probably meant they are in no position to purchase an external solution due to whatever restrictions or lack of funds (or being locked-in type fear) in place: there is no need to have a philosophical/merits discussion about them 😉
Message 6 of 11
Hey, Wood thanks a lot for your help. I tried to type that code in Autocad but i really do not have an idea for how to use it. Can you give me a tip about how to use that code ? Shall i type it directly in autocad (i cant paste it ). I mean should i paste it in to a text file then should i load it with appload ? I really did not understand it 🙂
Ps: Autolisps are ok to use too as long as the instructions are clear for a total noob.
Deniz
Message 7 of 11
Copy and paste the code into the command line, press Enter, then type ATTOUT, Enter.
Hope it helps.
Message 8 of 11
Unfortunately not, it only selects current layout's all items.  I need to select only the blocks in each layout. Please check the attached file.
Deniz
Message 9 of 11
In the case of your example drawing, please try the code below:
(sssetfirst nil (ssget "_X" (list (cons 0 "INSERT")(cons 2 "titleblock"))))
Message 10 of 11
Wood thanks a lot mate, it WORKED.
Cheers,
Deniz
Message 11 of 11
jcioffi
in reply to: 3wood
I stumbled upon this while searching for a way to update an amendment block across multiple sheets and this code was very helpful to me.  Thank you for sharing!
Is there a way to re-write it so that the block name is automatically filled in by clicking on the block, rather than having to manually type it into the code?
Thanks again!
”Boost
