I would like to know if there is a way / setting that I can turn of to where can do simple math problems when inputing numbers say for like offsetting a line without having to use AutoLisp.
I have searched on here for about an hour now and could not find an answer. I remember doing this in the past without having this issue.
For example if I was to offset a line I would type in "5.75/2" and get 2.875. I would like to be able to do this without having to type ( / 5.75 2).
Is there a way to do this without having to type all of that.
I am using AutoCad 2014, and at work we design driveline equipment so alot of the drawings are from a front view to a section view, and for like a round cover that is in the front view it is easy to offset the centerline in the section view by the radius and contine drawing the section view.
How can I do this???
Tony
Yeah the 'CAL works to do the simple math problems. But is there a way to do it without having to type in 'CAL.
You used to be able to do it without having to type in all these extra commands. I dont understand why I just cant type in 5.75/2 and get the answer that i want to use.
No, there has been no change in how calculations are done. The only exception is numbers expressed as fractions. In this case, both the numerator and denominator must be integers. Otherwise you can enter formulas in quickcalc or at the command line with 'cal (inside a command) or cal (outside a command) or by using lisp. Dean's suggestion was correct.
