Hello everyone,ı have a drawing and I want a part of the drawing not to be affected from object snap mode.In other words,ı want object snap catch only other part of the drawing(not the part I mentioned in the previous sentence). Is it possible in autocad? Thank you very much...
You could print those objects to PDF or DWF (or export to DGN), erase them from the drawing, and then import the DWF/PDF/DGN as a reference, then adjust the sysvar UOSNAP accordingly so that those objects are ignored.
It sounds like what you are looking for is a quick toggle for snaps on certain objects and this does not exist.
I know what you exactly what you mean. It is unlikely that you can eliminate the most common osnaps so make sure the object in the background only has end points and intersections, burst the circles and other rounds. Make it a block. Then while working in your “overlay” make sure you use the other osnaps like center and nodes.
I have added two buttons added to my custom palette
^C^C_OSNAP CEN,NOD
^C^C_OSNAP CEN,ENDP,MID,INT,NOD,
Try to make heavy use of the command _POINT to create nodes. or just make circles all over the place.
@ pendean thanks,
i was tweeking what i wanted to have active for a while and never updated my macro/buttons when someone told me about osmode... then i forgot.
