AutoCAD 2013/2014/2015
Distinguished Contributor
jz4all
Message 1 of 6 (242 Views)
How to bring jpeg logo on machine in 3D AutoCAD?
242 Views, 5 Replies
01-27-2013 11:59 PM
hi,
In 3D drawing, how can I bring (or paste) a logo (JPEG format) on equipment .  For instance logo of a company on a machine. How to do that in AutoCAD not Inventor.
Alfred.NESWADBA
Message 2 of 6 (237 Views)
Re: How to bring jpeg logo on machine in 3D AutoCAD?
01-28-2013 12:52 AM in reply to: jz4all
You can use command _IMAGE (looks similar to _XREF) and place the image within your drawing.
You can use the _RENDER-functionality, in that case create a meterial using that logo-image as texture map (maybe as bump map too) and assign that material to the logo-plate in your 3D-geometry.
- alfred -
Alfred NESWADBA
jz4all
Message 3 of 6 (195 Views)
01-29-2013 04:54 AM in reply to: Alfred.NESWADBA
Hi
Thank you for your response.
I tried but it doesn't work. the image stays separate from the equipment.In Inventor it is easyer (or because I don't know how to do it in AutoCAD) and the logo image becomes part of the equipment, even it follows the topography or profile of the equipment.
I'll be greatful if you know in steps how to do it in AutoCAD.
Jaf
Alfred.NESWADBA
Message 4 of 6 (184 Views)
01-29-2013 07:29 AM in reply to: jz4all
Do you mean that if you move your model then your image should move too?
It does ... if you use the way with material and mapping
it does not if you use the way with command _IMAGE, then you have to move the image if you move the model (or you create a block that contains model and image).
- alfred -
Alfred NESWADBA
Product Support
Message 5 of 6 (167 Views)
01-30-2013 06:34 AM in reply to: jz4all
Hi Jaf,
Have you tried creating a new material as suggested?
http://exchange.autodesk.com/autocad/enu/online-help/browse#WS1a9193826455f5ff-316fd70e123dece8002-5...
Cheers,
Luciane
Luciane Conceição
Product Support Specialist
jz4all
Message 6 of 6 (150 Views)
01-31-2013 04:52 AM in reply to: jz4all
Thanks a lot.
Jaf
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
