Hello.I'm working on printing industry by using some photoshop, illustrator and indesign. So what I'm doing is
not related to this. But, I'm interested in becoming an Autocad drafter. I have no experience and just doing self study.
Actually, I tried finding out some course in Architecture and Cad drafting. Unfortunately, the course is using different
type of CAD. I could find some course related to Autocad, but they are only a few times and the cost is very expensive.
Also, the time table doesn't match with my working. As a result, I decided to study and prepare the certification exam
by my self. At this stage, I have some question.
1. Is it possible to get a certificate by self study? Some of course I found out is designed to get a certificate. \
That's what they said.
2. Is there any website or book so that I can have a look the sample of exam? I've got some books. But the aim is to describe
the function and just put the mark as certification objet on it.
3. If I get a certificate, is it possible to get a job? I mean this is with out any taking course or experience.
How much advantage do I have if I have a certificate?
4. Is there any method to get apprenticeship by oneself?
thanks.
Learn the industry and process first, and then learn how to apply the available tools. That way, whether its AutoCAD Architectural, AutoCAD MEP, or Revit, the knowledge will be transferable. There aren't many drafting jobs out there anymore. Most of it is design work, where the person is expected to understand the principles and make basic decisions even if they don't have the authority to sign off as a professional engineer. Regardless of what papers you have if you can't size a beam you won't be doing structural design.
If you know how to use the software, find a job with a company and people willing to teach you, that works well too.
I started out learning to do BOARD DRAFTING (pencil on paper with a t-sqare and triangles) I took an ACAD class "just to see what it's like". I eventually studied and earned an Associates Degree in ARCHITECURAL CADD. But when it came time to look for a job, all the Arch firms I contacted said that they don't use drafters -- the Architects do their own drawings.
I ended up working for engineers and surveyors. In the beginning, I was always given red-line markups that told me explicitly what they needed. Occasionally, I'd ask why they did it this way vs that. For the most part, the engineer understood I wasn't trying to tell him he was "doing it wrong" but instead was just trying to learn. I did have one guy who REALLY TRULY seemed to think that I was trying to do his job by telling him my ideas were better than his -- but I just wanted to learn the reasoning behind the design.
Through this process, I learned enough that I've been able to take projects from start to finish with only minimal input from a designer.
This process has given me experience in ROW design, Roadway design, Site Design (parking lots, drainage etc) and a whole slew of other topics.
Don Ireland
Engineering Design Technician
I am sure that you can get a certificate through self-study. That in its-self is pretty good, and you may know the commands, but to use this to get a job, I would suggest getting your hands on AutoCAD first. If you don't know where the commands are on the ribbon, or have a good feel for what you are working with, you may find things a bit difficult. I currently don't have a certificate, but I only have about 30,000 hours working with AutoCAD, from AutoCAD 12 to AutoCAD 2015 Electrical. Most of my commands are 2 or 3 leter commands, about 3 dozen Lisp Macros that I put together or others (from this Forum) helped me to develop, and several Scripts that I created. As others will tell you, most companies are based on speed and general knowledge. One of the companies I worked for, I needed about 30 total commands. Our standards were buried in the Template, which held 3 of my scripts, and one set of plotting styles. Of the 8 drafters, none of us had a Certificate for AutoCAD, but all were very fast at Drafting and Design.
If you want to go to work as a AutoCAD Drafter. Get a course or two under your belt (either night classes or Saturday classes) to go with the Cert. That will be to your advantage. Before I forget, Youtube has some good classes, but it still isn't hands on.
A university or technical college that offers Autocad training would be the place I'd start. Being summertime schools aren't as busy as fall and spring so instructors would have fewer demands on their time. Express your interests to him/her and ask your questions. They will be in the best position to assist you at your particular location.
The other thing is a local user group if you're in a metro area; if not check the AUGI website for resources and information.
you can refer to this link Autodesk Academy, tutorials for beginner. thanks
As relevant as AutoCAD still can be, I'd lean towards learning something like Revit, Civil3D, Advance Steel, Inventor instead of AutoCAD.
With the world (and marketing) pushing more and more BIM, you'd be best off learning one or all of the above packages at some point.
I"m not the OP here? are you referring to my suggestion?
to be a good autocad drafter, experienced is the best teacher and with passion. thanks
