So I have 10 complex 3D splines and they are all similar in shape but not exact. Is there a way to somehow converge all of my splines into one average spline?
Thank you
Do they all have the same number of fit points? If so, presumably those could be extracted from entity data or the FitPoints VLA Property, and all 10 first ones averaged, all 10 second ones, etc., and put into a list, then that list fed to a new Spline command. Come to think of it, the way that FitPoints Property works, you could probably average those lists in their entirety, without needing to deal separately with individual points.
@Kent1Cooper wrote:
Do they all have the same number of fit points? .... the way that FitPoints Property works, you could probably average those lists in their entirety, ....
For instance [minimally tested, and could use a check on whether they all have the same number of Fit Points]:
(vl-load-com); if needed
(defun C:SA (/ qua n fitpts1 fitptsSum fitptsAvg); = Spline Average
(if (setq splss (ssget '((0 . "SPLINE"))))
(progn ; then
(setq
qua (sslength splss)
n qua
); setq
(repeat qua
(setq
fitpts1 (vlax-get (vlax-ename->vla-object (ssname splss (setq n (1- n)))) 'FitPoints)
fitptsSum
(if fitptsSum
(mapcar '+ fitpts1 fitptsSum); then
fitpts1
); if & fitptsSum
); setq
); repeat
(setq fitptsAvg (mapcar '(lambda (x) (/ x qua)) fitptsSum))
(command
"_.copy" (ssname splss 0) "" '(0 0 0) "@"
"_.chprop" (entlast) "" "_color" 11 "" ; to distinguish it [edit color # as desired]
); command
(vlax-put (vlax-ename->vla-object (entlast)) 'FitPoints fitptsAvg)
); progn
); if
); defun
@Kent1Cooper wrote:
.... could use a check on whether they all have the same number of Fit Points....
A more fully-developed version is attached.
.... but as it turns out, a Spline that is a result of Offset [of either another Spline or an Elliipse], or one that has been Broken, has nil for the FitPoints property, which throws the whole thing off [the result turns out the same as the first one in the selection]. And one that isn't like that but that was drawn with non-default directional instructions at the ends affects the result [if you pick one that is that way and one that isn't, you get different results depending on which one you picked first]. So I'm working on accounting for those things -- I've got it figured out for the ones that do have Fit Points, averaging both the FitPoints and ControlPoints Properties, but the other issue needs some thought, still....
