Does anyone know how to select an object that is part of an array without choosing the entire array? I've tried exploding the array, but each object is still configured as an array with 1 object. I've tried holding control while selecting an object in the array, but when I try to copyclip or copybase, the entire array gets pasted. Any suggestions on how to extract the original object from the array and be able to create another array with it?
Solved by GrantsPirate. Go to Solution.
@celloryno wrote:
...I've tried exploding the array, but each object is still configured as an array with 1 object...
If you create array from ordinary AutoCAD objects, then after exploding it with EXPLODE command you should get a set of ordinary AutoCAD objects, but not a set of arrays. So if you have Dynamic array and want to "extract" source object from it - than you can copy array, explode it and use source object from this array. If you get source object as an array after exploding - than array was created from array.
Maxim
I have one direct question about this: How do I do this without explode?
It is my opinion that whenever one uses explode - one is overlooking a better command to achieve the same, better.
As example: bedit instead of explode-edit-new block.
(or, more brutally: every time you use explode you admit your CAD incompentence )
Thus: any other options? Perhaps a button/switch in array edit? (or do we have to face the fact that it's a dynamic array, but not _that_ dynamic?)
Hold down the CTRL key and pick...
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Glad it worked. And if using the Ribbon you can pick the array, pick reset to get the object back that you might have erased or moved.
If not using the Ribbon, use ARRAYEDIT, pick array, use Reset option.
GrantsPirate
The NCOPY command will work, pick once for each object in the source.
GrantsPirate
Post a sample drawing and indicate what you are trying to delete (remove) from the array.
GrantsPirate
