I've tried to figure out the pattern of how the command works for inputting partial customization menu toolbar names but I'm unsuccessful.
You should be able to show and hide partial customization menu toolbars with the -toolbar command because it can hide all toolbars including my partial customization menu toolbars currently shown.
I've tried the toolbar menu alias (defined in the CUI command) and the name (refer to this link to the same image embedded below) and none work.
Any suggestions/solutions?
Thanks!
Doug
Solved by dbroad. Go to Solution.
If the toolbar name has spaces in it, you will need to enclose it in double quotes in order for AutoCAD to recognize it.
I'm sorry if you got that impression! You suggestion was the solution. That is why I gave your post a Kudo. 🙂
I was merely disappointed in myself for not thinking of it as you did.
Thanks again!
Workspaces are nice and we use them. Thanks!
I was merely trying to get the fastest way to turn on a specific toolbar for users. It seemed possible but I could not figure it out and this forum helped me as I had hoped it would.
