AutoCAD Forum
How do I find the Lat/Long for a point in a dwg file.
4 REPLIES 4
aj
Observer
493 Views, 4 Replies
4 REPLIES 4
ToddRogers-WPM
in reply to: aj
Use Civil 3D.
Todd Rogers
aj
Observer
in reply to: ToddRogers-WPM
That would be the easy way.. Unfortunately I only have AutoCAD..
ToddRogers-WPM
in reply to: aj
I think you're out of luck.  Unless you can use the GEOGRAPHICLOCATION command or GEOMAP.
Todd Rogers
jggerth1
if you have a known coordinate system, the Corpscon program available from ACOE will convert points to or from lat long.  If it is an arbitrary coodinate scheme, then it will be much harder to get valid info
”Boost
