AutoCAD 2013/2014/2015
Valued Mentor
Jason.Piercey
Message 1 of 40 (32,511 Views)
How To Install AutoCAD 2014 WITHOUT Autodesk 360
32511 Views, 39 Replies
04-15-2013 06:54 AM
As a few of you have already noticed, the installer for AutoCAD 2014 is broken, as is the uninstaller for Autodesk 360.  You can do a custom install and UNCHECK Autodesk 360 but it gets installed anyway.  Then when you uninstall Autodesk 360 via the control panel it causes issues with the properties palette in 2013 (if you have it installed) and 2014.  These palettes appear blank and non-functional.
If you've found yourself in this boat, the current fix is to uninstall 2013/2014 and reinstall to get either/both of them working again.  Doing a repair install does nothing to fix the issue.
If you are about to install 2014 for the first time and do not want Autodesk 360 installed you can do the following.  Thanks goes to Mike Burke for this work-around.
There is a simple edit in the setup.ini file (or the deployment ini file if you create deployments) that is needed to stop Autodesk 360 from installing.
In the setup.ini file look for the following line
POSTREQUISITE=ACAD_PSPACK;ADSYNC;ACADSKETCHUPIMPORT
Remove ADSYNC; from that line so you are left with:
POSTREQUISITE=ACAD_PSPACK;ACADSKETCHUPIMPORT
And that’s it. Autodesk 360 will not install when you use setup.exe.
An additional tip from Darren Young
Also note, if you want both options, copy setup.exe and setup.ini to setup-no360.exe and setup-no360.ini and edit that one.  Setup.exe will use the ini of the same name so you could have multiple versions available for install without constantly editing the ini file.
Hope this saves some frustration and down time for others.
Active Contributor
JGAo1
Message 2 of 40 (32,446 Views)
Re: How To Install AutoCAD 2014 WITHOUT Autodesk 360
04-15-2013 12:55 PM in reply to: Jason.Piercey
Thanks for the tip. I thought I omitted 360 before installing (the company firewall blocks it), but I put it down to old age!
JGA
Active Contributor
Darylt
Message 3 of 40 (32,003 Views)
04-28-2013 03:24 AM in reply to: JGAo1
Where do I find this Setup.ini file so that I can edit?  A360 is causing error messages with windows explorer.
Many thanks for help,
Daryl
Active Contributor
Darylt
Message 4 of 40 (31,994 Views)
04-28-2013 03:58 AM in reply to: Darylt
Update: Found the file and managed to install Autocad LT 2014 without A360. Lets hope that my issue with Windows explorer error message will now dissapear!
Would wish to use A360 in the future but will not touch it until Adesk undertake further testing and find the bug that is causing so much problems for many users.
Distinguished Contributor
RFUSE
Message 5 of 40 (31,969 Views)
04-28-2013 12:10 PM in reply to: Jason.Piercey
I have the DVD, how can I do this?
I have no use for 360.
R
Active Contributor
Darylt
Message 6 of 40 (31,966 Views)
04-28-2013 12:33 PM in reply to: Jason.Piercey
As per post 1 - you will find the setup.ini file on your disk (one is setup.exe and the other is setup.ini). Open the setup.ini file (usually opens in wordpad) and find the above line entry and edit (save the document when you leave the file). Now install the software and dont forget to untick A360 in customs option of install.
Best of luck,
Daryl
RFUSE
Message 7 of 40 (31,961 Views)
04-28-2013 01:39 PM in reply to: Darylt
Daryl,
I did not download from Autodesk, I received the DVD's.  One cannot change a file on the DVD.
R
*Expert Elite*
Alfred.NESWADBA
Message 8 of 40 (31,957 Views)
04-28-2013 02:00 PM in reply to: RFUSE
You can copy the content from your DVD to a local temp folder, there you can modify the files and install from that position.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
RFUSE
Message 9 of 40 (31,948 Views)
04-28-2013 02:14 PM in reply to: Alfred.NESWADBA
Terrific, didn't realize Autodesk allowed that.
THANKS,
R
*Expert Elite*
dgorsman
Message 10 of 40 (31,932 Views)
04-28-2013 05:40 PM in reply to: RFUSE
Whether download or from disk/thumbdrive, I always drop a copy of the installer on our network.  Even if something goes *really* wrong (somone borrows disc and leaves it on coffee cup warmer, office fire, etc.), I can always grab the installer from archives.
If you are going to fly by the seat of your pants, expect friction burns.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
